1990 c1500 5.3 6l80e swap
I changed the gauges to the needle cluster and just used a Dakota Digital module and makes all the stock gauges work. Oil pressure gauge doesn't work yet but haven't really tried to get it to work.
Yep, here it is. This is for a gen 3. It goes in the gen 3 oil pressure sender port at the back of the block. Not sure what the L83 uses.
https://www.speedwaymotors.com/LS-Se...ter,20928.html
The L83 with 6l80 will actually outperform a 6.0 with 4l80 on anything short of an all out build so you made a great choice. I'm curious about your low side fueling and electronics. Very nice to say the least!!!
Thanks everyone!
I believe i need the stock sending unit for ecu on the newer models but i could probably have a T adapter to have both sending units, just need to look into it a bit more.
I got the truck from Texas before i moved to Alberta.
I got a walbro 450 in tank pump and used a corvette fuel filter for the return system.
