1932 Ford pro street....re-build
Old May 23, 2013 | 08:08 PM
  #71
sprayed99's Avatar
Originally Posted by idahoblkss
look at post 61 second picture down .... newb ! lol
where are the turbos danny ?
Turbos are reserved for the next toy
Old May 23, 2013 | 09:07 PM
  #72
sprayed99's Avatar
Originally Posted by silver-mod-o
Considered relocating the coils under the body while you've got the wiring apart? It would clean up the top of the engine a bit.
What coils????
Old May 25, 2013 | 10:55 AM
  #73
silver-mod-o's Avatar
Hunt&Fisherator
Looks damn good. The first drive will make it all worth it
Old Jun 12, 2013 | 07:29 PM
  #74
sprayed99's Avatar
Tiny update: Still trying to move some things around at the shop and get 2 cars out of there so I have enough room to bring it out where I can actually get some **** done.
SPD 1.75" Flanges... I will be building 1.75 to 1.875" stepped longtubes
GM MLS Gasket fit
Test fit on engine... these things are built perfect.... they better be they are just under 200.00 a set LOL.
I also ordered some more 1.75" bends and a power XS starter and 150amp polished alternator from powermaster. Hopefully it will show up next week.
Old Jun 21, 2013 | 07:02 PM
  #75
sprayed99's Avatar
Not much has been done with all the work we have at the shop. Got bored after work one day and decided to do some polishing. I polished the bracket I made and the stand offs. Also got my power master 150amp alternator on.
Old Jun 22, 2013 | 12:58 AM
  #76
idahoblkss's Avatar
Looking good Danny. What head bolts did you use? I also love that crank bolt too. Is it nessisary to vent the oil cap on a non boosted app.?
Old Jun 22, 2013 | 03:36 PM
  #77
sprayed99's Avatar
arp bolts on anything that is holding anything vital together. no the vent isnt needed, but why not I had it laying around
Old Jun 22, 2013 | 04:47 PM
  #78
chevrolet all the way's Avatar
thats pretty slick man! from all your post its obvious you are building the truck with great detail! i love a flat head, but you have done a great job with the swap!
Old Jun 23, 2013 | 12:23 PM
  #79
Spoolin's Avatar
GFYS and STFU
Ahhh...so happy to see an LS motor in these early Hot Rod trucks! Personally I'm not a fan of the flat head stuff. This is sweet! Looking forward to seeing this on the road. Nice job with the alternator too!
Old Jul 26, 2013 | 03:49 PM
  #80
sprayed99's Avatar
A small update as I managed to get a small bit of work done. I do not have a Tig at home so I had to use the Mig to make the transmission crossmember. Also got the harness 99% completed. It is sitting at BP Automotive waiting to have the PCM pins crimped on and the 80 pin connectors installed. Also scored a caravan seat for 20.00 which I may or may not keep. Got the steering column bracing finalized and the vintage air box mounted too! You can also see the start of the ignition switch/headlight switch panel.... it is still in "rough" shape.
All pictures are from my shitty cell phone as the Nikon battery was dead!
Harness ready for a box
Caravan seat in mock up
Transmission crossmember from mock up to complete (minus paint) All it made from .250 mild steel.
Steering Column and AC box with dash placed in position
Start of the switch panel
