14 BOLT BUILD (mucho pictures)
Old Feb 15, 2011 | 12:17 AM
  #31
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by Three6GMC
Cool would like to do this mod in the future what all is needed to make the hd rears a 6 bolt? And my truck being a nnbs is it the same? Basicly what your doing is making a hd rear into a hybrid 1500 rear correct like the max trucks?
Bassically What we have done is take a 2000 chevy light duty 3/4 ton 9.5 14 bolt SF rear end and install 6 lug axles from a 89-98 K1500 Truck.
Why? Because there are 2 diffrent axle bearings. The 06ss style 14 bolt Uses a 1.622 od axle shaft and the OBS 3/4 use a 1.703 shaft if you see the bearings side by side its easy to see why we went this route... Its Should hold the extra power and I have not yet found 1 OBS axle that broke on its own un like the newer style that uses the smaller shaft and bearing. You can get forged axles for the smaller bearing but why spend the extra money...
https://www.performancetrucks.net/fo...d.php?t=467473
  #32
SLOXCAB's Avatar
looks good pat. when is that private track day
Old Feb 15, 2011 | 12:21 AM
  #33
EVILGMC's Avatar
Friday March 4
Old Feb 15, 2011 | 12:22 AM
  #34
EVILGMC's Avatar
Should be noted that this setup is about 1 inch shorter overall when compared to the factory nbs 10 bolt.
I have not personally checked, but do believe any NBS 2500LD or 1500HD axle housing will work for this type of swap.
Old Feb 15, 2011 | 12:24 AM
  #35
SLOXCAB's Avatar
Originally Posted by EVILGMC
Friday March 4
damn i gotta hustle. either way ill be there pit crew mang
Old Feb 15, 2011 | 03:20 AM
  #36
Spoolin's Avatar
GFYS and STFU
Looks awesome Pat!! Can't wait to see the results at the track!! No more clink clink bang at the 60 foot mark!!
Joseph, great work. Might hit you up one day this year for mine. I know you have more than a few 14 bolts laying around!!!
Now about that POS in the backround of this picture...looks familiar, almost like there's some lazy homo that I know that just doesn't want to finish his project...who could it be?
Old Feb 15, 2011 | 04:01 AM
  #37
1FastBrick's Avatar
Now thats a low blow... You know it has nothing to do with Me or Money so lets leave that Buissness off the forums...
Old Feb 15, 2011 | 04:16 AM
  #38
1FastBrick's Avatar
Originally Posted by 2004SSS
you going to try it out at fontucky? looks awesome i like this option better for the positioning of the caliper alone . nice work guys!!!!
Chase, If you decide to go this route later on with a 14 bolt hit me up.
I saw you were inquiring about a 9.25 swap up front and a possible gear ratio swap. I cant wait to see how that turns out.
Old Feb 15, 2011 | 07:42 AM
  #39
JoeyGC5's Avatar
Good looking setup/install.
1fastbrick I see what you were refering to as the clocking of the brack caliper.
Old Feb 15, 2011 | 08:55 AM
  #40
08Chevy's Avatar
those welds are amazing lol.
Looks good.
