14 BOLT BUILD (mucho pictures)
#54
did you guys have the pumpkin/tubes in a jig when you welded up the axle tubes? wondering if it had any warping problems and it can be done in truck without worrying about warping the tubes . i was thinking of just migging them while it was in the air just dont want to warp anything.
#59
#60
There is some deflection in the housing from use. Once its welded up with the bar centering it, most of the deflection is gone.
Im not a big fan of trying to do it while its assembled. As EvilGMC saw from the one that was in a fire it distorted so bad the one axle was extremly difficult to get out even with a sledge hammer.
The rapid heating and cooling from the Mig welding process will likely add to the distortion. Not to mention the heat could distort the pinion seal just enough to leak and cook the Oil in side makeing a smelly mess. The other problem you face with mig welding cast iron is crystalization at the weld area from rapid heating and cooling. I have been told that using a gas torch to preheat and post heat will help.
Chase let me know if you need some help.
