03 SS awd turbo street build
Old Dec 1, 2017 | 06:33 AM
  #111
97_ek's Avatar
That's a good looking exhaust, and the truck is awesome as well. Keep up the good work!
Old Dec 1, 2017 | 11:07 PM
  #112
SDjeff619's Avatar
Nice, looks good. I hate exhaust, I did mine all custom stainless and it turned out great but it’s a pita. That will look good.
Same here, it’s a pain cutting plumb lines, filing, beveling, etc. especially with pie cuts.
Originally Posted by 12secSS
Very nice ,very clean nice work..Can you tell me what QA1 shocks they are .thanks
Thanks, which ones, front or rear?
Old Dec 2, 2017 | 03:59 AM
  #113
12secSS's Avatar
The rear ones ,thanks
Old Dec 2, 2017 | 10:32 AM
  #114
SDjeff619's Avatar
DS902 but you will need some Allstar spacers for the attachment points.
Old Dec 2, 2017 | 01:20 PM
  #115
12secSS's Avatar
thanks ...good luck with your truck
Old Dec 3, 2017 | 10:51 PM
  #116
SDjeff619's Avatar
Hood number 2. This is the only hood I found that I actually like. The first one ordered from JC Whitney arrived with seven dents on the top. I bought this one from Summit and showed up flawless. There are slight alignment issues with the driver front but that will get worked out. Also adding a pic of the Street Scene 3 piece bed rails and tailgate spoiler. Everything will be painted once the truck is running.
Old Dec 11, 2017 | 05:16 PM
  #117
hutch311's Avatar
Did you have to paint or powder coat your Z06 brake calipers black or is there a part number for them? I can find GM OEM in red, silver and yellow on ebay. Thanks in advance.
Old Dec 13, 2017 | 10:43 AM
  #118
SDjeff619's Avatar
I painted them.
Old Jan 19, 2018 | 10:42 AM
  #119
SDjeff619's Avatar
I finally finished the entire exhaust system with Cerakote coatings with their highest temp material at 2000 degrees. I'm impressed with how this stuff lays on the surface. Even when I was a little heavy while spraying in the beginning, it didn't run or drip.
The key is the prep. I smoothed everything out with a sanding disk. Then sand blasted. I don't have access to a big oven so I spent hours washing all parts and scrubbing with a brilo pad "Greenie Weenie". Wiped everything down multiple times with acetone.
If this stuff stands up to the heat/cycles, I'll be spraying the Kooks on the CTS-V and the Thunder Header on the Dyna.
Got the new front and rear drive shafts from Drive Shaft Specialist in Texas. They have amazing customer service. They built them to my specs in a couple of days and shipping was quick. I think now the weak point in the driveline is the front and rear diffs.
Old Jan 19, 2018 | 11:29 AM
  #120
SDjeff619's Avatar
Those of you running the big radiator and the LS3 water pump, I found this Gates radiator hose to fit almost perfectly. Gates P/N 22147.
The Hellwig solid front sway bar compared to the stock bar. The Hellwig is beafy as hell weighing 35lbs and the stock bar weighed 11lbs.
Also finishing up the front end with new Moog HD pitman, idler arm, idler support and these bad *** Kryptonite 1/2 ton tie rods.
In the middle of the SS project I decided to drop my girls 2011 Tahoe with a Belltech kit w/ shocks from NorcalSS. I gave her my gloss black 24" Sierra reps as well.
The steering and suspension collection between the two trucks. I also came across a pair of stock sway bars from another nnbs Tahoe for $25. Plan to put the rear on the SS.
