03 Silverado Step Side Build "StepChild"
#142
I thought I did. I also mounted them above the a-arm, to get more extension out of them. I will find out how it does real soon. The ones i picked up had the same travel as stock front shocks within .3. Its the compression side im kinda of leary about with them mounted above. When i get the trans back in and the truck lowered back down, i can see what im working with. I think it will be fine though.
#146
I will have to take measurments, but I do know this, the top a arm was maxed on its stop on extension without the shock. I was able to bolt up the shock on top of the bottom a arm and below without changing the tops position. so its fully extended with the shock mounted, same way with the stock shock.
#150
Formerly ScreamingL
