03 Silverado Step Side Build "StepChild"
Old 10-12-2015, 05:46 PM
  #141
Formerly ScreamingL
George C....'s Avatar
Did you make sure shock had enough travel
Old 10-12-2015, 05:57 PM
  #142
fastjweb's Avatar
I thought I did. I also mounted them above the a-arm, to get more extension out of them. I will find out how it does real soon. The ones i picked up had the same travel as stock front shocks within .3. Its the compression side im kinda of leary about with them mounted above. When i get the trans back in and the truck lowered back down, i can see what im working with. I think it will be fine though.
Old 10-12-2015, 07:06 PM
  #143
fastjweb's Avatar
Went with these measurements for the front, stock height 2wd
Extended Length (in): 14.380 in.
Collapsed Length (in): 9.380 in.
Old 10-12-2015, 07:17 PM
  #144
Formerly ScreamingL
What is distance from control arm to top of shock mount with shock unhooked and suspension fully extended
Then what is measurement of fully collasped
Old 10-12-2015, 07:20 PM
  #145
03chevytruck's Avatar
Looking good!! Im shopping for front/rears shocks as we speak. I've been thinking of just going the budget route with adjustables Rancho 9000XL and you just had to post pictures of those!! lol Now i want those again!
Old 10-12-2015, 08:06 PM
  #146
fastjweb's Avatar
I will have to take measurments, but I do know this, the top a arm was maxed on its stop on extension without the shock. I was able to bolt up the shock on top of the bottom a arm and below without changing the tops position. so its fully extended with the shock mounted, same way with the stock shock.
Old 10-12-2015, 08:07 PM
  #147
fastjweb's Avatar
they are 156.00 right now on summit, qa1 wants 180.00 i believe. bears are 124.00 i think.
Old 10-12-2015, 08:13 PM
  #148
GMCtrk's Avatar
Have you tried different adjustments on the caltracs?
I backed mine off (less preload, bushing just touching leaf) and I hooked on all runs compared to prior with 1/4 turn preload.
Old 10-12-2015, 08:27 PM
  #149
Hmm i'll check them out. I thought they were alot more than that. Do you have the part #s? I found the rancho fronts for $70 and rears for $92.
Old 10-12-2015, 08:35 PM
  #150
Formerly ScreamingL
Thats good...you want a shock longer then you have droop
Quick Reply: 03 Silverado Step Side Build "StepChild"
