03 rclb joe dirt build.. 4L80e and single turbo 4.8
Old 07-12-2014, 07:03 PM
  #21
98tdi's Avatar
This is how it sits now..
End result was 507 whp. Very happy with the outcome. I have a couple of 6.0 motors and am throwing the idea around of swapping the cam in the 6.0 and tossing it in there..
The turbo is very big for this small motor and take a little bit to spool.
Old 07-12-2014, 10:36 PM
  #22
Custm2500's Rude Friend
1FastBrick's Avatar
How did you do the rear frame for your conversion?
Old 07-13-2014, 08:23 AM
  #23
98tdi's Avatar
I opted to cut the rear section of frame off and move everything on the frame forward versus cutting the middle of the frame and welding it back together.
I think it's on the second page in a link if you want pictures..
I used all the measurements on gmupfitter.com.
The conversion came out perfect, didn't even need it aligned!
Old 07-13-2014, 08:53 AM
  #24
Great numbers!! How many pounds of boost?
Old 07-13-2014, 10:34 AM
  #25
1FastBrick's Avatar
Been awhile....
Truck is officially a shortbed now.
Mobile Uploads Photos by dking14 | Photobucket
The link to your photobucket is set to private. I can't see them
Old 07-13-2014, 10:38 AM
  #26
98tdi's Avatar
It's on 9# until I get headstuds, then I will turn it to 14#
I will post them up here in a bit then
Old 07-13-2014, 10:51 AM
  #27
98tdi's Avatar
Moved the leaf spring mounts forward
Here the rear section has been cut and is laying on the ground.
The leaf spring perch mounts are now in the correct location and mounted
Hope this helps. I did this in my attached garage on my house!
Used a miller 211 mig welder to weld the mounts, relocate the gastank strap support bar etc.
I have since put around 6000 miles on it and haven't had any issues yet
Old 07-13-2014, 10:56 AM
  #28
1FastBrick's Avatar
Did you have to make any new mount holes for the bed in the frame or move any of the mounts?
Did you flip the rear brace around so you can still mount a spare tire under it?
Old 07-13-2014, 11:42 AM
  #29
98tdi's Avatar
I moved the second bed mount and did have to drill new holes in the frame,
All the locations are given on gmupfitter.
I opted to not re-install the bar for my spare tire but it is easily done by moving the bracket forward.
Rafe19
10-18-2016 12:27 AM
03regcab sierra
20
08-03-2015 12:11 AM
Ammadien
07-22-2015 08:50 PM
Cowboy17
07-09-2015 08:22 PM
Quick Reply: 03 rclb joe dirt build.. 4L80e and single turbo 4.8
