03 rclb joe dirt build.. 4L80e and single turbo 4.8
#21
#23
I opted to cut the rear section of frame off and move everything on the frame forward versus cutting the middle of the frame and welding it back together.
I think it's on the second page in a link if you want pictures..
I used all the measurements on gmupfitter.com.
The conversion came out perfect, didn't even need it aligned!
#25
The link to your photobucket is set to private. I can't see them
#26
#27
Moved the leaf spring mounts forward
Here the rear section has been cut and is laying on the ground.
The leaf spring perch mounts are now in the correct location and mounted
Hope this helps. I did this in my attached garage on my house!
Used a miller 211 mig welder to weld the mounts, relocate the gastank strap support bar etc.
I have since put around 6000 miles on it and haven't had any issues yet
#28
Did you have to make any new mount holes for the bed in the frame or move any of the mounts?
Did you flip the rear brace around so you can still mount a spare tire under it?
#29
All the locations are given on gmupfitter.
I opted to not re-install the bar for my spare tire but it is easily done by moving the bracket forward.
03regcab sierra
20
Aug 3, 2015 12:11 AM
