**Three6GMC Official Build Thread**
#541
It would have been way cleaner to just use a Tee fitting for the fuel pressure sensor.
I highly recommend some turbo blankets for the turbos, even "bad" ones will help tremendously with underhood heat.
#542
To be honest not as loud as you would think. I think a muffler that has a lot of drone is louder inside. Now on the outside it's a different story it's just plain loud. You mainly hear all turbo whistle. I can talk normal and listen to music going down the highway no problem when the windows are up, when it gets into lock up it quiets down a lot. I still have every intention to put down pipes on the truck and route the exhaust to the back but for now doesn't bother me at all.
#543
I did this at 2am and didn't have one at the time. I got some new fittings coming with my JEGS order Friday. Turbo blankets are on the list as well.
#544
#545
Very cool. Thanks for posting. Didn't even know such a product existed. Shows how much I mess with big power intank pump stuff. lol
#546
Oh also because the pump uses -8 size ORB fittings on the suction and discharge and the sock is a -10 an I ported the pump fitting to match the internal diameter of a -10 fitting. This is on the pump suction so my thinking is anything helps....
Stock untouched fitting on the left vs one after matching it to a -10 fitting. Plenty of material thickness left on the threads of the -8 side. Basically turned the suction to a true -10 AN (⅝) size. Will it make a difference? Hell if I know but hopefully it helps. Oh also don't mind my ugly fingers lol I had just cleaned the parts off with some brake clean and got some on my hands.
#547
If you get the -ORB fittings from Magnafuel the actual ID is much larger. Most people don't understand and get all worked up when Magnafuel tells them to feed the pump with a -12 but shows the 4303 to use a -8 fitting on the website and in the instructions. What these people don't realize is that the -8 ORB is much larger than a regular -8. Clear as mud, I know. Why they don't post that info in bold letters on their site, I don't know.
Completely off subject but have you or anyone's else had any issues with a brand new Magnafuel pump? Mine was brand new ordered it from Summit and when I went to install it the first time the damn thing wouldnt run. It was locked up and just made a clunking sound. It came filled with oil and had the red caps still on the inlet and outlet when I pulled it out of the box. I losened up the inlet cap on it and put power to it and it ran great, but as soon as I would tightened down on the inlet cap to the gears it would lock up. It's like it was machined wrong or something. I ended up taking off just a bit of material from the shafts that the gears connect to and it worked. Pump at first sounded like it was under a lot of load at 55psi but is loosening up some because it's starting to run louder and faster. At idle I have had to lower the base pressure down a few pounds for the third time now so seems like it's pumping better and at a higher rpm. So far holding steady so I thinks it's loosened up as much as it's going to. I got a second one coming so I'll swap it with another brand new one and see what that one does.
#548
I'd pull the post filters off now and see what is going on there.
Regarding the pump, never heard of an issue like that. Obviously there is a pump/gears clearance problem if what your saying is true. Unfortunately, getting anyone at Magnafuel to listen to you now after you have machined their pump/gears isn't gonna happen, right or wrong.
I'd definitely pull it back apart and check the filter cause you still have something going on there.
#549
Yeah I'm not gonna bother Magnafuel about it, I got it to work and anyways got the new one coming in tomorrow. Ill inspect the old pump when I pull it back out. So far the post filter looks good.
