wot switch
Old Jun 17, 2009 | 04:50 PM
Superado's Avatar
11 Second Truck Club
Default wot switch
want one to interact w/ the cable driven throttle control...
want to wire it up so I have to be @ wot AND have a button mashed...
what are you guys using?
pics? part #'s? source?
thanks in advance!
al
Old Jun 17, 2009 | 05:36 PM
DAH32's Avatar
I would like to know as well.
Also:
What type of bracket are you using for your microswitch on the cable driven LQ4 or truck intake?
Old Jun 17, 2009 | 06:02 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Pedal switch. Why the push button? I just use a window switch, activation switch and a pedal switch. All 3 must be closed before any gas is released.
Old Jun 17, 2009 | 06:27 PM
LowBlack99's Avatar
What he said. Very least a toggle to arm the system (turns the solenoid on) then a WOT or a momentary switch to spray. I used a momentary for stealth purposes.
Old Jun 17, 2009 | 09:43 PM
Superado's Avatar
the push button I mention would be a momentary...
I want to hold a momentary button down...mash the pedal to wot to activate a micro switch @ the throttle cable "cam" and then release the momentary right after launching
was gonna wire the momentary and the solenoid to a relay and instead of grounding the momentary, run it to the micro switch...
that was my thoughts on wiring it up anyway...am I not looking @ it correctly?
Old Jun 18, 2009 | 12:34 AM
LMSeven's Avatar
So you want a micro switch that's activated at WOT inline with a push button that you push right after launch to engage? So the push button is dead until the micro switch is activated at WOT?
Old Jun 18, 2009 | 12:39 AM
nonnieselman's Avatar
yep..
http://www.harrisspeedworks.com/prod...&cat=66&page=1
you can get theses suckers at Radio shack for a decent price..
I moved mine to the gas pedal in the truck cause it stuck out like a sore thumb under the hood :devel:
Old Jun 18, 2009 | 12:42 AM
Mine is wired up like this....
Power to the Master arm switch..
Arm that switch, then the purge and WOT switch have power.. Always have my hand on the arm switch just incase..
Also have to wire up the 2step to the nitrous.. so when the 2 step is armed i can hold the pedal to the floor, then when i let off the brake the nitrous sprays..
Old Jun 18, 2009 | 06:55 AM
Superado's Avatar
you got it!
Old Jun 18, 2009 | 04:50 PM
Superado's Avatar
thanks guys!
keep the suggestions and pics coming!
