wot switch
want one to interact w/ the cable driven throttle control...
want to wire it up so I have to be @ wot AND have a button mashed...
what are you guys using?
pics? part #'s? source?
thanks in advance!
al
thanks in advance!
al
the push button I mention would be a momentary...
I want to hold a momentary button down...mash the pedal to wot to activate a micro switch @ the throttle cable "cam" and then release the momentary right after launching
was gonna wire the momentary and the solenoid to a relay and instead of grounding the momentary, run it to the micro switch...
that was my thoughts on wiring it up anyway...am I not looking @ it correctly?
yep..
http://www.harrisspeedworks.com/prod...&cat=66&page=1
you can get theses suckers at Radio shack for a decent price..
I moved mine to the gas pedal in the truck cause it stuck out like a sore thumb under the hood :devel:
Mine is wired up like this....
Power to the Master arm switch..
Arm that switch, then the purge and WOT switch have power.. Always have my hand on the arm switch just incase..
Also have to wire up the 2step to the nitrous.. so when the 2 step is armed i can hold the pedal to the floor, then when i let off the brake the nitrous sprays..
