Who's Running a Brand X kit from Nitrous Outlet
Old May 11, 2011 | 10:27 PM
dmelvin's Avatar
Default Who's Running a Brand X kit from Nitrous Outlet
I was just curious who, if anyone is running a brand X kit from NO.
If you've got any tips for install/pictures that would be primo. I'm already running bigger injectors and soon to be a 255lph pump, so I'm not overly concerned about fueling yet, at this point I have no plans on ever spraying over 100, and if I need more fuel at that point, I can cross that bridge when I come to it.
I was curious how everyone mounted their bottle, ran the lines/wires, etc. This is something I may look into getting sooner than I expected.
Old May 11, 2011 | 11:29 PM
charcoal03silvy's Avatar
I helped zaneregan install his brand x dry kit. I say install... i was moral support We ran the wiring straight to the WOT swtich then to the noid. No relay. Ground and power came off of battery. Mounted bottle in bed ran line under the truck. Pretty simple just time consuming. The wire connectors supplied with the kit didn't work like we wanted so we made a few trips to Oreillys
Old May 11, 2011 | 11:57 PM
Steve-O-08's Avatar
I have my HSW kit, but it's all pretty much the same. Going to get some pictures up this weekend, just have to finish one or two loose ends.
Old May 12, 2011 | 12:14 AM
Steve o how much are you spraying? Stack trans?
Old May 12, 2011 | 12:48 AM
Steve-O-08's Avatar
75 shot right now. stock trans with an HD2 and servos. I think I may be the only one on here running a dry plate kit.
Old May 12, 2011 | 12:52 AM
Think I could get away with a 125 shot on the stock trans if I leave some torque management and dont spray through shifts?
Old May 12, 2011 | 01:19 AM
Steve-O-08's Avatar
Tune is set up to 50% torque management and I don't spray through the shifts. I can step up from 75, just keeping it mild for now. I want to get a wideband before I move up from there.
Old May 12, 2011 | 05:10 AM
2007chevy5.3l's Avatar
My friend is now running a 150 shot on the stock trans with only a servo and an agressive tune with 0 torque management and sprays thru the shifts. Its already had six 100 shot bottles and three 150 shot bottles thru it. No slipping yet lol
Old May 12, 2011 | 07:15 AM
My trans also has 120k on it!
dmelvin's Avatar
Interesting... I thought it was really recommended to spray a dry shot before the MAF. I thought the ring system seemed kinda intriguing too.
