what drilling is required?
Old Mar 25, 2009 | 01:28 AM
ZQ8Dude's Avatar
Default what drilling is required?
I might be looking to do some N20 for my next mod, but i dont know what would be the best way to mount it in my truck. I don't really wanna drill into the truck's body
So i was thinking that a bed mount would be best, but then how would i mount it in the bed, especially with a bedrug in there.
Just looking for some ideas/opinions. Would there be room to run lines through the firewall??
Old Mar 25, 2009 | 08:31 AM
krambo's Avatar
I mounted it in the bed requiring the bed to be drilled into:
Old Mar 25, 2009 | 09:05 AM
WJ MARK's Avatar
how about under the truck with a remote opener???? Stealth and space saving!
Old Mar 25, 2009 | 09:33 AM
texasbullseye89's Avatar
until that one pothole takes his bottle out. lol. Mine (when I can order it within the next 5 years....) is going in the cab, probably behind the passenger seat.
Old Mar 25, 2009 | 09:54 AM
mcfarlnd's Avatar
Un-Registered User
mine is in the bed. directly in front of the passenger side wheel well. if you have it in the cab around here, you have to have it vented to the atmosphere.
Old Mar 25, 2009 | 11:00 AM
How do you do that
Old Mar 26, 2009 | 12:34 AM
chevytruckguy's Avatar
You can run the nitrous feed line along the fuel lines if you don't want to go through the firewall. I went through the main wiring harness grommet, just make sure not to cut or break any wires. If you want to mount it in the truck you can glue/silicone/liquid nails a board under the carpet and use bolts to mount the bracket. I ran the blowdown tube out the cab vent on the rear of the cab.
Old Mar 26, 2009 | 12:52 AM
A Low Dime's Avatar
13 Second Truck Club
WOW!! That is friggin CLEAN looking, nice job. I want to re do my placement like that with a bed rug.
Old Mar 26, 2009 | 01:02 AM
ZQ8Dude's Avatar
Well, i have a plan if i mount on the inside as for as the bottle.
Under the rear seat is a plastic tool box. remove that, and then i just gotta make a mounting plate that uses the same bolts.
Old Mar 26, 2009 | 12:02 PM
Should work out good. Does the NNBS have the cab vents on the back of the cab? I haven't looked at one close enough.
