what drilling is required?
I might be looking to do some N20 for my next mod, but i dont know what would be the best way to mount it in my truck. I don't really wanna drill into the truck's body
So i was thinking that a bed mount would be best, but then how would i mount it in the bed, especially with a bedrug in there.
Just looking for some ideas/opinions. Would there be room to run lines through the firewall??
You can run the nitrous feed line along the fuel lines if you don't want to go through the firewall. I went through the main wiring harness grommet, just make sure not to cut or break any wires. If you want to mount it in the truck you can glue/silicone/liquid nails a board under the carpet and use bolts to mount the bracket. I ran the blowdown tube out the cab vent on the rear of the cab.
Under the rear seat is a plastic tool box. remove that, and then i just gotta make a mounting plate that uses the same bolts.
