What controller?
Old Jan 27, 2011 | 07:38 AM
00buckshot's Avatar
Default What controller?
Guys out there that are on 2 stages, what controllers or progressors are yall using? I was thinkin of goin with the HSW Micro edge+. seems to be a nice unit. thanks for your time and suggestions
Old Jan 27, 2011 | 07:55 AM
mcamarols1's Avatar
Microedge+ and the lingfelter timing module.
Old Jan 27, 2011 | 08:35 AM
00buckshot's Avatar
Does the micro edge+ not control timing? I read the specs on it yesterday but I'm burnt out on reading, sorry if i missed it
Old Jan 27, 2011 | 08:57 AM
Bigschwerm's Avatar
Which Timing Module...you have a link?
Old Jan 27, 2011 | 11:03 AM
00buckshot's Avatar
You can find the lingenfelter on nitrous outlets site
Old Jan 27, 2011 | 11:28 AM
mcamarols1's Avatar
Microedge does not pull timing. http://www.lingenfelter.com/mm5/merc...w=&range_high=
Old Jan 27, 2011 | 01:43 PM
00buckshot's Avatar
I'm thinkin about the microedge+ and using the HSW interace, if i recall correct, the hsw interface will only pull 8* of timing, is it only capable of pulling 8, or will it pull from 2*-8*? would like a good bit of adjustability if anyone has any other suggestions
Old Jan 27, 2011 | 07:37 PM
Steve-O-08's Avatar
+1 for the Microedge. I'm running the HSW Interface so I can adjust timing/fuel with it.
Old Jan 27, 2011 | 09:58 PM
brandon6.0's Avatar
with the interface jb u can pull 3* with the controller. But it can also control a/f ratio and make sure everything is working. So, with this function it can pull out as much as u want tho. This is done by changing a certain row of your IAT spark advance table. Maybe harris speed will chime in.
I am running one with a fjo progressive and it has been doing me pretty good so far.
Do u remember that day we was playin around on the way to savania speedway, with your old truck. I think i had the 5.3 or maybe 6.0 not sure. But anyways my setup was completely stock tuned computer. I was spraying, by using this controller ONLY to control timing and top end fuel. Done me pretty good.
Old Jan 28, 2011 | 07:39 AM
00buckshot's Avatar
HAHA, that was just the baby 5.3, that was original motor that came in that truck and died with it, man those were the fun days when things were cheap, looks like im gonna go with the micro edge+ and the interface, stilll would like to know how much timing i would be able to pull for sure as i'm plannin on a healthy shot
