What controller?
Guys out there that are on 2 stages, what controllers or progressors are yall using? I was thinkin of goin with the HSW Micro edge+. seems to be a nice unit. thanks for your time and suggestions
Microedge+ and the lingfelter timing module.
Does the micro edge+ not control timing? I read the specs on it yesterday but I'm burnt out on reading, sorry if i missed it
Originally Posted by mcamarols1
(Post 4627772)
Originally Posted by Bigschwerm
(Post 4627798)
Which Timing Module...you have a link?
Microedge does not pull timing. http://www.lingenfelter.com/mm5/merc...w=&range_high=
I'm thinkin about the microedge+ and using the HSW interace, if i recall correct, the hsw interface will only pull 8* of timing, is it only capable of pulling 8, or will it pull from 2*-8*? would like a good bit of adjustability if anyone has any other suggestions
+1 for the Microedge. I'm running the HSW Interface so I can adjust timing/fuel with it.
with the interface jb u can pull 3* with the controller. But it can also control a/f ratio and make sure everything is working. So, with this function it can pull out as much as u want tho. This is done by changing a certain row of your IAT spark advance table. Maybe harris speed will chime in.
I am running one with a fjo progressive and it has been doing me pretty good so far. Do u remember that day we was playin around on the way to savania speedway, with your old truck. I think i had the 5.3 or maybe 6.0 not sure. But anyways my setup was completely stock tuned computer. I was spraying, by using this controller ONLY to control timing and top end fuel. Done me pretty good. |
Originally Posted by brandon6.0
(Post 4628347)
