Spraying through shifts?
Old Mar 1, 2007 | 04:52 PM
UBLUZIN03's Avatar
Default Spraying through shifts?
Whats exactly does this mean? I know its kinda self explanitory but exactly what does it mean, and what can be done to help out with the trans? I read putting a shift kit and servo in help?....
Old Mar 1, 2007 | 05:02 PM
RoosterMcCandles's Avatar
Spraying through the shifts means that while you are going through the gears, your truck is continually spraying. As you change gears, the nitrous is still spraying. A window switch will alleviate this problem by briefly turning the nitrous off while you shift and resuming again after you shift. You can get a shift kit and a servo if you want but it is going to be money wasted if you want to spray through the shifts on a 4L60E...
Old Mar 1, 2007 | 05:34 PM
UBLUZIN03's Avatar
I figured thats what is was. Is the window switch manditory? Will i be okay with out it for a little bit?
Old Mar 1, 2007 | 05:37 PM
It work fine without a window switch. A window switch is just good if you want to spray it within an RPM range like most guys want to...
Old Mar 1, 2007 | 05:43 PM
speedy02's Avatar
I dont spray through the shifts. It turns off 200 rpm before it shifts.
Old Mar 1, 2007 | 06:17 PM
a new level's Avatar
Sorry had to butt in. speedy02 that sig is phat!!
Old Mar 1, 2007 | 07:30 PM
UBLUZIN03's Avatar
So if i want to run it at the track w/o a window switch ill be alright?
Old Mar 2, 2007 | 12:25 PM
99Silverado5.3's Avatar
Yeah, but if you're spraying through shifts UBLUZIN 4l60e lol. Do you have a wot switch or what? How is it activated? I recommend getting a window switch from nitrous outlet w/ the built in TPS (Throttle Position Sensor)
Old Mar 2, 2007 | 12:40 PM
I'd get a window switch before I start messing around with it if I were you. You can get a used one for ~$80 which is much cheaper than a new transmission...
Old Mar 2, 2007 | 12:47 PM
onebadrubi's Avatar
THink about it another way. Your already spraying a ticking time bomb, unless its built. I would NOT spray through my shifts when I first got nitrous. Now i would rather spray through them then load and unload 3 times in the 1/4.
