Spraying through shifts?
Whats exactly does this mean? I know its kinda self explanitory but exactly what does it mean, and what can be done to help out with the trans? I read putting a shift kit and servo in help?....
Spraying through the shifts means that while you are going through the gears, your truck is continually spraying. As you change gears, the nitrous is still spraying. A window switch will alleviate this problem by briefly turning the nitrous off while you shift and resuming again after you shift. You can get a shift kit and a servo if you want but it is going to be money wasted if you want to spray through the shifts on a 4L60E...
Originally Posted by UBLUZIN03
So if i want to run it at the track w/o a window switch ill be alright?
THink about it another way. Your already spraying a ticking time bomb, unless its built. I would NOT spray through my shifts when I first got nitrous. Now i would rather spray through them then load and unload 3 times in the 1/4.
Sorry had to butt in. speedy02 that sig is phat!!
