Spend my money! Which kit?
Nitrous outlet plate kit hands down. Im sure NX has a nice kit but I prefer N2Outlet. Also, about your timing, there is a way to pull timing when you arm the kit with the switch. Im not exactly sure how but my friend has it on his TA. I will post back when I find out.
lingenfelter lnc2000 works really nice
Lingenfelter Adjustable Launch Controller - Timing Controllers - Electronics & Ignition
There have been a few changes to this method but the concept is still the same.
When the relay is activated, the IAT is set to a set value. Then with either HP Tuners or EFI Live you can command a certain amount of timing to be pulled. If you have tuning software you can do this yourself pretty easy. If not, you can set up the wiring and have your tuner set up the timing retard.
