Spend my money! Which kit?
If you were to buy a kit right now, which would you buy? Run down of the truck:
2006 Silverado ss Built 65 Yank 3600ss Btr custom grind 227/236 .613 .578 113+3 Btr platinum springs Tbss intake swap 1 7/8 pacesetters Full3" exhaust Arp head studs and rod bolts I'd like to put 150+ down its throat. It's tuned at rpm motorsports in nc. I'm looking for a nice kit, possibly a plate setup. I plan to eventually do a a standalone and switch to a Vic jr with a 4150 plate. I'm looking for which kit you guys recommend for me, also, which plugs are recommended and at what gap? It will be a learning curve for me so I plan to start conservative and increase with confidence. Any advice other than pulling timing? |
Nitrous express makes a very very nice plate setup. Very nice price and an even nicer kit.
nitrous outlet plate kit with hard lines
How is everyone pulling timing? Most of you have hpt at home ?
Just throw the kit on and take it back to Ryan for a retune buddy.
That's the plan initially, but I just don't like the idea of running around with timing pulled when it doesn't need to be.
Think iv narrowed it down to:
nx express proton base kit Nx express jet kit Nx express switch panel Nitrous outlet acc pack incl: bottle heater/bracket, gauge, fpss, nhra fitting, blowdown, purge Nos 2 stage tps/ rpm window switch Tr6 plugs gapped .035-.038 Sound about right? I figure I'll start with a nozzle and depending on if I change intakes or not, when I decide I'll get the corresponding plate. |
everything looks good except for the tr6. you need a non projected plug.
BR6EF is a non projected TR6.
Br6ef it is!
