Small DRY SHot ...before mass or after
Old Mar 1, 2010 | 11:32 AM
JJB's Avatar
JJB
Default Small DRY SHot ...before mass or after
Zex says never mount dry shot before mass air flow device...thinking about putting an very small shot and already have a an older zex kit but really not wanting to use the managment box ...was thinking about tapping the end of the cone air filter and running it through the mass/ maff...therefore bypasing their FMU....any thought on this ? putting a 35 pill which is rated 65HP shot on a V6 so probably smaller HP on a V8,(they dont have a jet for 50HP shot so iam guessing with the 35Pill), but not wanting anything over a 75 shot preferably like staying around a 50 shot...anybody done this or must i use the vacume box / mounts to fuel pressure regulator and mount it after the mass in the air pipe?
Old Mar 1, 2010 | 07:37 PM
454navyss's Avatar
i have always heard to spray a dry shot before the MAF and a wet shot after the MAF
Old Mar 2, 2010 | 05:34 AM
JJB's Avatar
JJB
me too thats why its kinda confusing ...if i do put it on will probably just do it before mass...thanks for the reply
Old Mar 2, 2010 | 05:47 AM
Mangled03gmc's Avatar
Baltimore Whore
Before with the a dry shot, after with the wet shot, because you have fuel to compensate it with the wet shot..
Old Mar 2, 2010 | 05:57 PM
Burgundy&TanMan's Avatar
I ran dry shot before the maf for years with no problems, and i sprayed 100shot.
Old Mar 3, 2010 | 12:26 AM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
Before the mass air meter. Keep in mind nozzle movement can alter tyhe tune. I would either suggest taking the zex dry nozzle and cutting the tip off and then place it in the end of the filter. A better option would be to ditch the nozzle and go to our distribution ring. It will completley fog the air intake making sure the mass air meter always sees the same flow path.
Dave
Old Mar 3, 2010 | 02:35 PM
JJB's Avatar
JJB
thanks for the responses after much contemplation and as good as my truck runs now I think iam gonna hold off on the spray ...i do like the spray bar that ND has though i forgot you had that...I bought a complete/ heater package everything / set up off you for my Z28 and was really happy with 0 issues ...ran perfect everytime thanks ND...
Old Mar 5, 2010 | 10:18 AM
Nick@HSW's Avatar
FormerVendor
Another option, had you kept on the path of spray, would have been to use our Interface controller and go post maf. Then you won't even have to worry about dialing in the nozzle position to obtain optimum a/f.
Nick
Nick@HSW's Avatar
FormerVendor
Nick
Old Mar 5, 2010 | 12:57 PM
No problem.. If I were you I would sell the Zex system and put a good wet system on the truck and go have fun.. Ofcourse when ever the time is right..
Dave
twake_410
Apr 14, 2016 09:58 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Slammed silverado
Sep 28, 2015 06:14 PM
2ktransam
Sep 28, 2015 09:19 AM
vipergtrdj
Sep 11, 2015 05:52 PM
