Question? Nitrous + Turbo
Old Oct 17, 2008 | 08:49 PM
DiRtYSTS's Avatar
Default Question? Nitrous + Turbo
I have an 03 SilveradoSS with a STS Turbo kit running 10#s of boost. Im thinking of running a 75-100 shot off the line until the boost kicks in. Ive tried high stall converters but I heard this would give me more bang for my buck off the line and would be less wear and tear on my tranny/engine.
Does anyone have any experience with this or any recommendations? Recommended kits? Thanks
Old Oct 17, 2008 | 08:53 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
No way is a 75 or a 100 shot less stressful on anything. It's about as stressful on parts as it gets. With Turbo you want load...A high stallng converter would be anti-productive as I understand it.
DO a small shot start at 35-50....take it slowly man!
Old Oct 17, 2008 | 10:19 PM
Start it off with a small converter, and the go for the nitrous kit.
Old Oct 18, 2008 | 02:02 AM
DiRtYSTS's Avatar
Thanks, for the advice. That makes sense to me!
Old Oct 18, 2008 | 02:38 AM
nonnieselman's Avatar
Good Gosh!! 100 shot with 10# boost
that should be fun!
you have more info on your truck?
im guessing a 60E?
Can you get any boost off the line? I would do Hydroboost brakes setup or a 2 step if you cant..
Old Oct 18, 2008 | 02:44 AM
95 bright teal's Avatar
Im with nonnie, what tranny and what else has been done? is it AWD? what size tire?
Old Oct 18, 2008 | 10:30 AM
DiRtYSTS's Avatar
My truck is AWD with a recently built 60E w/stock converter still. Ive been through a tranny or 2 already. I had a high stall 2500-2800 on my last tranny but to get any boost out of it or a good launch I would have to brake stall the hell out of it. My current mods are: STS Turbo w/GT67 ATA intercooled 44# injectors, Snow meth kit, stock headers, cats removed.
Im wasnt planning to run the 75-100 shot at 10#'s of boost. I was planning to hit the NO2 of the line just until my boost kicks in. Just to make up for the lag of the line.
Old Oct 18, 2008 | 10:43 AM
well here is what I did.. I had the vacuum brakes and I tried to brake stall it at the line my pedal would be to the floor and it would start pushing thru the front brakes.
So I gathered my parts and put a 50 wet shot on mine through a plate.
We have a 500' track here local. I ran a 7.9@71? 2.3 60' with just boost.
I'd brake stall it to ~1600 and it sprayed as soon as I went WOT. it dropped me down to a 7.0@80ish with a 2.0 60'.
Now with hydroboost brakes I've ran a 7.2@76 with a 2.0 60'. that's leaving the line at 4psi.
it ran a 6.85@79 1.9 60' leaving the line at 4psi spraying at WOT..
A 50 shot is a lot more that you would expect with boost.
so if you do decide to spray it, start low at 35 or so.
You have a wideband and tuning software?
Old Oct 18, 2008 | 09:42 PM
ntmd8tr's Avatar
Wow Now I'm wondering. I have around a 3400 stall and no nitrous and cut a 1.90 60' the other night and in the cooler weather I am getting around 3psi on the launch. It will go 5 but the light didn't drop so I had to back out. I was skeptical of the converter but now I like it. Good luck man Just start low and work your way up.
Old Oct 18, 2008 | 09:45 PM
How much boost are you running?
5.3lSilverado
25
Aug 29, 2016 12:48 AM
X_Racing1
21
Mar 30, 2016 02:37 PM
08lambochevy
Aug 7, 2015 11:42 PM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
