No Pistons!
Old Sep 8, 2005 | 07:18 AM
white lightning SS's Avatar
Default No Pistons!
Only forged pistons available are custom (900.00+). If you keep stock pistons
and add forged rods will the stock pistons hold 10.5 psi boost and 125 shot?
thanks for the info.
Old Sep 8, 2005 | 07:47 AM
Fogle07's Avatar
check out texas speed. they got some diamond pistons for 529. they prob. would cut you a little better deal. call and talk to jason.
http://www.texas-speed.com/9904Truck...Fld=9904Trucks
Old Sep 8, 2005 | 07:48 AM
Fogle07's Avatar
the mahle pistons are also under 600
Old Sep 8, 2005 | 08:40 AM
These Pistons Are All Ls1 Bore Sizes 5.7. Do They Make 5.3?
Old Sep 8, 2005 | 08:45 AM
Fogle07's Avatar
you plan on boring your block when you change pitons? the smallest ones they got are 3.905 but i would call jason up and see what he says. ill look more into it for you though
Old Sep 8, 2005 | 09:17 AM
you cant bore the iron 5.3 only .010 to 3.632
Old Sep 8, 2005 | 09:26 AM
Fogle07's Avatar
im not sure about what you can bore them to. i suggest you call jason and tell him what you got and what you want to do and he should be able to hook you up with what you need. he gave me a killer deal on some pushrods yesterday.
Old Sep 8, 2005 | 11:28 AM
white1's Avatar
Fogle, pm me with this "killer deal" if you dont mind
I have heard/read the 5.3 can be bored to the 5.7 bore, but I would double check that just to be sure. There are plenty of threads on it
Old Sep 8, 2005 | 11:43 AM
Kano's Avatar
WLSS
sent you a PM
Old Sep 8, 2005 | 11:51 AM
02sierraz71_5.3's Avatar
Id have it sonic tested, Ive heard of people boring alot more than that.
