No Pistons!
Old Sep 8, 2005 | 04:10 PM
white lightning SS's Avatar
I guess what i am getting at is can I run a 75-100 shot and 10.5 ps1 boost
on thes pistons. I am thinking cast pistons my shatter?
Old Sep 8, 2005 | 04:19 PM
Fogle07's Avatar
that i dont know of but if you have the money and you want to put some good pistons in then you should go ahead and do those diamond pistons or the je's and put some good rods in it. go ahead and have your heads worked while your in there also. you wont be dissappointed and then you will also be able to step up the shot when you want to.
Old Sep 10, 2005 | 08:54 AM
KySilverado's Avatar
Old school was if you want N20 you want forged pistons. Period.
Old Sep 11, 2005 | 08:30 AM
oxidizr's Avatar
Moderator / Sponsor
5.7 bore can be achieve with 5.3 iron blocks
Nitrous does NOT require forged pistons but they are more resistive to detonation harmonics making the motro more survivable in poor tuning or out of specs runs.
Old Sep 11, 2005 | 12:43 PM
Grey Silver's Avatar
11 Second Club
The stock pistons are not cast, they are hyperutectic[spelling?] A lot of people are using these type of pistons in nitrous and boost applications. With a good set of rings they'll work fine. If you run too lean or have detonation the forged pistons may hold on for a few more seconds but there are no pistons that will hold up under those conditions.
Old Sep 12, 2005 | 08:53 PM
Thanks for all the help. I got a 5.3 aluminum block from a little birdie and I'm boring it to 3.905 thes pistons are readily available in cast and coated so I can boost and spray the **** out of it! w/ good tune of course.
Old Oct 10, 2005 | 03:11 PM
MPFD's Avatar
11 Second Truck Club
you can only bore a 5.3 block 10 thousands, I've been researching and it is hard to find affordable 5.3 pistons. You can buy a LS1 crate for about $4200, That isn't much more than you will spend building a 5.3 liter.
Old Oct 10, 2005 | 04:19 PM
Rhino79's Avatar
9 Second Club
Nitrous and high compression equals BOOM! Nitrous likes lower compression.
Old Oct 10, 2005 | 06:33 PM
Rhino79's Avatar
9 Second Club
Well, it does like high compression too. But with the increased cylinder pressures with the use of nitrous, the higher the compression, the higher the chance of detonation. So then you would have to take out a bunch of timing. I think that is why piston companies offer lower compression pistons for nitrous applications.
Old Oct 13, 2005 | 03:16 PM
FarmerBeau's Avatar
Sexy Party Mod
STOP!!! YOU CANT BORE AN ALUMINUM BLOCK TO LS1 BORE SIZE...NO WORKY. I have read in the LS1 bible (how to build high performace LS1/LS6 V8s) that you cant go as crazy with the boring on an Aluminum 5.3 as you can on the iron 5.3. DONT DO IT!!!! Aluminum blocks have sleaves in them and the sleaves are not thick at all. Bore the iron block to LS1 status!!
