nitrous question ????
Old Nov 16, 2007 | 04:44 PM
TEXASMADECHEVY's Avatar
Default nitrous question ????
i been wantin to add nitrous to my truck and i have a kit but not sure if it is complete bought it from a friend awhile back it has the throttle switch, bottle, soleniods fuel and nitrous, window switch, fuel lines,relay and nozzle do i need anything else??? if i dont is there anyone in houston that can help me install it cause i really dont want to pay like 350 to get it installed!! another question is do i need to change my spark plugs? if so what is the best to get?what else would i have to do to the truck to get it nitrous ready?? its an 06 with a 4.8. thanks in advance
Old Nov 16, 2007 | 10:52 PM
sprayed8's Avatar
make sure you have a long enough nitrous line to mount the botle where you want, and you should probably get a warmer to go with the kit. i dont know much about the window switches, but it seems like you have everything for an install. depending on how much you spray, you are going to wan to go with a colder set of plugs. one heat range colder should do, but if your gonna spray over a 100 shot, 2 colder couldnt hurt.
Old Nov 16, 2007 | 10:55 PM
dirt track racer 81's Avatar
bottle heater will be needed...ngk tr6 are the norms
Old Nov 17, 2007 | 09:48 PM
WJ MARK's Avatar
fuel pressure safety switch.
Old Nov 18, 2007 | 08:24 PM
sprayed8's Avatar
+1 my ZEX kit has one built into the controller so thats a little piece of mind i am thankful for.
Old Nov 18, 2007 | 08:38 PM
tarinitup's Avatar
9 Second Truck Club
I think a window switch should come before the bottle heater if funds are limited. Your tranny will last longer too.
Old Nov 19, 2007 | 07:13 AM
sprayed8's Avatar
tarinitup is right, better inurance for your money with the window switch. trannys are expensive
Old Nov 19, 2007 | 10:34 AM
I Alredy Got An Msd Window Switch So All I Need Is A Bottle Heater And Plugs Now I Have To Find Someone To Install It
Old Nov 19, 2007 | 12:04 PM
sprayed8's Avatar
its pretty easy to do yourself so it might be worth a try to save some money. i started my install and i was gonna have a shop finish it if i got in over my head, but i didnt have to. i did my buddies kit for him to. give it a try, ou can always have it finished later if you want.
Old Nov 19, 2007 | 01:59 PM
brodystruck's Avatar
It's easy just allow yourself plenty of time to do it correctly...
blownss27
Aug 14, 2020 08:27 AM
gavin2005
Sep 13, 2015 09:04 PM
06 4.8
Sep 11, 2015 10:36 AM
iregret
Sep 7, 2015 01:20 PM
06murder
Sep 4, 2015 03:54 PM
