Nitrous Outlet plate bracket question
Old Sep 21, 2011 | 10:34 PM
OneBadRR's Avatar
Default Nitrous Outlet plate bracket question
Is anyone running a 78mm truck plate with the plate bracket? I'm getting ready to order a plate and I like how clean the install is with the solenoids mounted to their bracket. Problem is, I have a couple of NOS brand solenoids, and I'm unsure if they will fit. Thanks!
Old Sep 22, 2011 | 04:37 PM
SRTKLLR's Avatar
The install is very clean. You can't tell it even has nitrous unless you know what to look for. I am not sure if your solenoids will work with there bracket though. If you look under my name you will find my install thread.
If you decide to sell your current setup and want to get the NO plate kit let me know as I have one at home.
Old Sep 22, 2011 | 05:03 PM
Beatdown Z's Avatar
Laid Back
What year is your truck?
Old Sep 22, 2011 | 05:09 PM
OneBadRR's Avatar
Old Sep 22, 2011 | 09:12 PM
Beatdown Z's Avatar
Laid Back
So you're DBC. I ran into a lot of issues with my truck specific plate kit, so plan on running new hardlines and ditching the ones the kit comes with.
Old Sep 22, 2011 | 09:17 PM
OneBadRR's Avatar
DBW actually. 02 Escalade with an LQ9. I'm not too worried about the plate and bracket fitting, more so that my NOS brand solenoids fit behind it. In the picture on the website, it seems that the Nitrous Outlet brand solenoids are small, and my NOS brand are fairly hefty. Sent an email last night shortly before starting this thread and have had no word back yet.
Old Sep 28, 2011 | 10:32 PM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
We have resolved the hardline issues. Took us alittle while to determain there was some differences between different makes with the same year model. They fit great now.
Dave
Old Sep 28, 2011 | 10:34 PM
Our brackets are designed for our Bottom exit solenoids. Our solenoids are big so it has nothing to do with the size. The NOS noids will more than likely bolt up. If the bolt pattern is slightly off thats nothing a drill bit would not fix.
Our hardlines will not work with the nOS solenoids though.
Dave
Old Sep 29, 2011 | 05:58 PM
Beatdown Z's Avatar
Laid Back
Dave
Sooooo... You wanna send me the nitrous hard line for a 78mm DBC setup with the early style truck water pump?
Old Sep 29, 2011 | 06:17 PM
Yes sir.. shoot me a pm with your contact info.
Dave
X_Racing1
21
Mar 30, 2016 02:37 PM
The_W
Oct 28, 2015 09:00 PM
USMCvet0311
Aug 1, 2015 07:45 AM
USMCvet0311
Jul 29, 2015 01:28 PM
slowlsx
Jul 13, 2015 04:18 AM
