maybe im overthinking this?
Old Oct 14, 2013 | 02:03 AM
Jake75's Avatar
Default maybe im overthinking this?
I got the proton kit wired to a purge kit, tps sensor, and window switch they all tie into the same arming switch. The tps and proton kit are on separate relays..how does the window switch control the spray at a certain rpm if it isnt hooked to the solenoids in any way they just share the same power wire. i havent sprayed yet so im still questioning how its going to work
I used these diagrams for a base minus the fpss and the Mallory unit. Also it's not wired to wot switch its wired with a tps switch
Old Oct 14, 2013 | 06:59 AM
custm2500's Avatar
Ph.D. in HUBRIS
I would erase and throw away the FPSS as most everyone does. If you do it now it will save a few headaches before you decide to throw it away.
I don't remember how my MDS switch is wired. I will take a look this afternoon if you don't get a for sure answer.
Old Oct 14, 2013 | 09:16 AM
NitrousExpress's Avatar
Former Vendor
The MSD switch is supplying a ground signal to the relay to activate it. Also you don't need to have the TPS on a separate relay.
Trey
Old Oct 14, 2013 | 03:34 PM
Jake75's Avatar
Thanks guy I was looking all over online for a answer think this clears it up for me
}BlueFire{
Oct 3, 2014 05:03 AM
greasemykey
Nov 15, 2013 06:07 PM
Jeebalow
Jun 30, 2013 11:45 PM
Z71crawford
Dec 30, 2012 11:18 AM
bluchev
Jun 25, 2010 06:43 PM
