maybe im overthinking this?
I got the proton kit wired to a purge kit, tps sensor, and window switch they all tie into the same arming switch. The tps and proton kit are on separate relays..how does the window switch control the spray at a certain rpm if it isnt hooked to the solenoids in any way they just share the same power wire. i havent sprayed yet so im still questioning how its going to work
I used these diagrams for a base minus the fpss and the Mallory unit. Also it's not wired to wot switch its wired with a tps switch
I would erase and throw away the FPSS as most everyone does. If you do it now it will save a few headaches before you decide to throw it away.
I don't remember how my MDS switch is wired. I will take a look this afternoon if you don't get a for sure answer.
}BlueFire{
Oct 3, 2014 05:03 AM
