Guys with bottle under back seat
Old Feb 16, 2009 | 08:17 AM
nonnieselman's Avatar
Originally Posted by trever1t
Just make sure you use a heavy gauge wire to the heater...
My dynotune Heaters say they are 300 watts... and if anybody knows their electricity, 300 watts at 12 volts is 25 amps... and if your engine is running it should be at 13.5-14 volts which drops the amps down 21.5amps... So at a minimum run 10awg wire and a good 40 amp relay and a 30amp fuse.
Should be ok then.
Old Feb 16, 2009 | 08:19 AM
Originally Posted by viciousknid
thanks for ruining my plan
HAHA, well you can touch it, but maybe only for a second.
Im not touching my bottle heater..
Old Feb 16, 2009 | 12:22 PM
Parke10's Avatar
yea no ****, they get pretty damn hot, when jaegmc99's was first installed it was basically melting his carpet.
Old Feb 17, 2009 | 04:16 PM
silver-mod-o's Avatar
Hunt&Fisherator
I always either had the seat out or flipped up when I had my heater on so it wasnt an issue, either way, with my HSW heater, it never got hot enough to hurt anything anyway.... I normally threw a jacket over the bottle just so it wasnt so blatantly obvious.
Old Feb 17, 2009 | 05:05 PM
Holty's Avatar
Notorious BIG
My back seat is either folded up or completely removed when i turn my heater on. But mine gets HOT, i know i could put my hand on it, but not for very long.
ARC
57
Feb 21, 2022 10:54 AM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
