Guys with bottle under back seat
Old Feb 15, 2009 | 10:43 AM
southern_chevy's Avatar
Default Guys with bottle under back seat
Hey I have my bottle mounted under the back seat and was wondering what yall do with the heater. Cause my bottle is touching the bottom of the seat and I know the bottle heaters gets pretty worm. So do yall worry about the back seat or just raise it up when you go to the track?
Old Feb 15, 2009 | 11:04 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Put the heater so its under the bottle.
Old Feb 15, 2009 | 11:20 AM
sounds good I have not put the heater in yet just knew that the bottle hit the seat. Thanks man
Old Feb 15, 2009 | 02:24 PM
99Silverado5.3's Avatar
Don't worry about..doesn't get that hot.
Old Feb 15, 2009 | 02:32 PM
ZR1 DREAMING's Avatar
Put the heater on the bottom side of the bottle, then go get some of the heat sheild fabric(like the NASA stuff) just to be safe if you're still concerned to line the bottom of that portion of you're seat.
Old Feb 15, 2009 | 11:38 PM
ZZebes's Avatar
the outside never gets hot enough to light the fabric
Old Feb 16, 2009 | 12:06 AM
viciousknid's Avatar
Where's the Beef?
you can actually put your hand on it
Old Feb 16, 2009 | 12:35 AM
nonnieselman's Avatar
I turned my heater on and let it sit for 20 minutes and hit it with a Fluke Infared.. it showed 240* in the center and 200* on the other porion of the heater.. Now that I have 2 extra heaters I'm goin to completly wrap my bottle.. that should warm it up faster.
Old Feb 16, 2009 | 12:42 AM
Where's the Beef?
thanks for ruining my plan
Old Feb 16, 2009 | 07:53 AM
trever1t's Avatar
Just make sure you use a heavy gauge wire to the heater...
