ecsb bottle mounting
Old Dec 24, 2009 | 11:33 AM
454navyss's Avatar
Default ecsb bottle mounting
i want to mount my bottle under my back seat but i wont be able to put the seat down if i do, where are ya'll mounting your bottles? is there a reason for the brackets making the valve side of the bottle higher than the bottom of the bottle? i was thinking i can go get another short bracket, which would set the bottle completely horizontal, and it would fit under the back seat.
Old Dec 24, 2009 | 11:41 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Mine is mounted under the rear bench, driver's side, nozzle forward. The bench closes fine, bottle is at standard tilt. You want the bottle nozzle up so the the pick-up tube inside the bottle is covered with gas and nozzle forward so that when you launch the gas goes back to the bottom of the bottle and not away from the pick up tube, understand?
I have a bracket from Nitrous Dave and it fits just fine, room to spare. DON"T forget your blowdown tube.
Old Dec 24, 2009 | 12:44 PM
454navyss's Avatar
ok, that makes sense. i wanted to have the bottle sideways under the seat since i have people ride in the back seat pretty regularly and didnt want them kicking something loose. i have a blowdown tube but need to send it back to Nitro Daves for a 90* tube.
you dont have pics of your bottle installed do you?
Phantom's Avatar
11 Second Club
yep mine was mounted under the back seat too with no issues
Old Dec 24, 2009 | 01:10 PM
trever1t's Avatar
I did, but I deleted them off PB, need to get into my hard drive at home and repost. Basically the bottle is mounted ~5" from the hump. Yeah, you need the 180* blow down tube, come straight up then U's down.
Old Dec 24, 2009 | 02:58 PM
TxStVanWilder's Avatar
Carey go search for pics of virgil's setup, he had his mounted under the rear seat
Old Dec 24, 2009 | 03:30 PM
454navyss's Avatar
im looking....checked here and silveradoss.com, nothing yet
Old Dec 24, 2009 | 03:46 PM
Black'Rado's Avatar
didnt Virgil have a 15# bottle under his seat? or am i thinking wrong? i want to mount my bottle in my center console for a hiddin system
Old Dec 24, 2009 | 04:34 PM
trever1t's Avatar
Went home and dug these up for you, hope it helps, merry christmas
This is a 10lb. bottle, not sure if a 15 can squeeze in there or not, never compared size.
Old Dec 24, 2009 | 05:00 PM
454navyss's Avatar
you didnt have to do that. thanks though Bill. i have a 10lb bottle so i may just have to do it like yours. thanks again and Merry Christmas to you too
