150 shot..
Old Jul 21, 2010 | 01:01 PM
liftedwhite94's Avatar
Default 150 shot..
I was going to put a cammed 6.0 in my truck but funds and it being my DD I've decied against it. So im buying a NX wet fogger kit from a member here, about how much time in the 1/8 should i look to pick up with 150shot? My truck has 4:11 gear, 3500ptc stall, headers,tune on the drag radials it'll run 8.8xs all night with a 1.89 60 ft
Also, Can anybody post pictures of were they mounted there solenoids and were they put the fogger at?
Old Jul 21, 2010 | 01:24 PM
RandomHero's Avatar
This guy dropped a full second:
https://www.performancetrucks.net/fo...t+1%2F8th+mile
Old Jul 21, 2010 | 03:01 PM
Black'Rado's Avatar
I would start the shot small and see how it reacts and also allows you to make sure your tune is good while spraying.
Old Jul 21, 2010 | 05:23 PM
I talked to dynospeed, he said to bring it down with the nitrous and he will re tune it on the 150 and if i wanted more we could move it up to 200
Old Jul 21, 2010 | 06:51 PM
how safe would a 200 shot be with a good dyno tune?
Old Jul 21, 2010 | 06:53 PM
RandomHero's Avatar
With just the base kit you were interested in, I wouldn't do it man. I only ran a 150 shot and had all that safety stuff: window switch, bottle heater, pressure switch, fuel pressure safety switch,etc.
Honestly I never had to use any of it, but if I ever did need to it would have saved my motor.
Most people on here don't go bigger than 150
Old Jul 21, 2010 | 07:14 PM
Black'Rado's Avatar
yea id stick to the 150 max, id be more worried about the tranny on a 200 than the motor though
Old Jul 21, 2010 | 07:43 PM
custm2500's Avatar
Ph.D. in HUBRIS
I say start at 100 so you have some room to grow. Run that for a wile then step up some. I wouldn't be afraid of running a 200 shot but being your DD I would make sure you have a part fund set up just incase. On a 200 shot you are starting to push the limits of anything stock.
Old Jul 21, 2010 | 07:47 PM
its got a tru trac and built 60e. I'm just going to stay with the 150. Thanks guys
about how much should I look to pick with with the tune/150 nitrous?
Old Jul 21, 2010 | 08:41 PM
Phantom's Avatar
11 Second Club
