100 shot on installed
Old Aug 14, 2011 | 01:16 PM
laoutlaw's Avatar
Default 100 shot on installed
Just finished installing my wet kit. I is a nos nitrous kit. I have it set for the 100 shot. Just woundering if I should go with the blackbear mail order with Justin or put it on a dyno. Being a 100 shot and a wet kit do I need to put it on the dyno. I have read different reviews on this. Any help will be appreciated.
Old Aug 14, 2011 | 01:31 PM
Bigschwerm's Avatar
If it was my truck and still on a stock tune I would go out and run it...that's just me though.
Old Aug 14, 2011 | 01:52 PM
6789olds's Avatar
do you have a LS engine ? or the L31 like me ? what size jets are u running for your 100 shot ?
Old Aug 14, 2011 | 02:01 PM
laoutlaw's Avatar
I think it is 33 fuel and 54 nos. Not for sure. It is a l31 all stock but bolt ons.
Old Aug 14, 2011 | 02:16 PM
6789olds's Avatar
your stock tune will be good because the stock timming is very consevative . at those HP levels i would not run a stock plug u should swap to atleast a tr6 gaped .32-.35, i am useing ngk BR6EF #3177 I use n.052 f .032 my nitrous calculator says 122hp at the flywheel. your N.054 F .033 is 132hp shot if u wanna run on your stock plugs i would drop down your hp level .
Old Aug 14, 2011 | 06:15 PM
laoutlaw's Avatar
i have a custom tune for what i have done to my truck. i have a full exhaust[ long tube headers and straight pipe with a x pipe], k&n cold air intake, 373 gears, polished throttle body, e-fans, bigger spark plug wires, msd coil, no a/c[took it out]. i went with ngk br7ef plugs. they are 2 steps colder than stock.
Old Aug 14, 2011 | 06:45 PM
6789olds's Avatar
do you know how much timming u have ?
Old Aug 14, 2011 | 07:23 PM
2007chevy5.3l's Avatar
Outlaw you wont hurt anything with the 100 shot. Just use the br6s and if you dont already have a wideband get one and watch it to make sure your at an ok A/F
Old Aug 14, 2011 | 08:23 PM
laoutlaw's Avatar
Not sure about the timing. My brother inlaw has a scan tool I am thinking of getting from him and plug it in to my truck and see what it does. How much does a wideband cost and where can I get one. I was going to go with a whole new run from blackbear so that i know what has been done to the pcm. The plugs that I have in it right now are 2 steps colder than the stock ones. I think that I am ok there.
Old Aug 14, 2011 | 10:10 PM
6789olds's Avatar
lots of people run this wide band Innovate DB Digital Air/Fuel Ratio Gauge with LC-1 Kits - SummitRacing.com
the plugs u have will work great with your nitrous . if your timming at wot is 26*or less you will be set . and u will be buying extra bottles lol i went threw the first few bottles quick .
2500ZL1
Jan 25, 2016 06:30 AM
urdone
Aug 18, 2015 12:17 PM
Dirtywhite
Aug 5, 2015 04:10 PM
vmaxpro
Aug 4, 2015 07:02 AM
Mzay
Jul 6, 2015 11:05 PM
