100 shot on installed
Just finished installing my wet kit. I is a nos nitrous kit. I have it set for the 100 shot. Just woundering if I should go with the blackbear mail order with Justin or put it on a dyno. Being a 100 shot and a wet kit do I need to put it on the dyno. I have read different reviews on this. Any help will be appreciated.
your stock tune will be good because the stock timming is very consevative . at those HP levels i would not run a stock plug u should swap to atleast a tr6 gaped .32-.35, i am useing ngk BR6EF #3177 I use n.052 f .032 my nitrous calculator says 122hp at the flywheel. your N.054 F .033 is 132hp shot if u wanna run on your stock plugs i would drop down your hp level .
i have a custom tune for what i have done to my truck. i have a full exhaust[ long tube headers and straight pipe with a x pipe], k&n cold air intake, 373 gears, polished throttle body, e-fans, bigger spark plug wires, msd coil, no a/c[took it out]. i went with ngk br7ef plugs. they are 2 steps colder than stock.
Not sure about the timing. My brother inlaw has a scan tool I am thinking of getting from him and plug it in to my truck and see what it does. How much does a wideband cost and where can I get one. I was going to go with a whole new run from blackbear so that i know what has been done to the pcm. The plugs that I have in it right now are 2 steps colder than the stock ones. I think that I am ok there.
lots of people run this wide band Innovate DB Digital Air/Fuel Ratio Gauge with LC-1 Kits - SummitRacing.com
the plugs u have will work great with your nitrous . if your timming at wot is 26*or less you will be set . and u will be buying extra bottles lol i went threw the first few bottles quick .
