100 to 150 shot swap
see thats the thing I dont know I dont have a guage I know I need one. The guy that filled it told me not to heat it cause he put some pressure in the bottle, I guess that he filled it a little fuller. I dont know but by the way he talked it should have plenty of pressure in it. But thats only for the first pass I guess, since it would start loosing pressure as you use it with no heater. Right?
Also, sometimes when your bottle gets filled, it can bend the siphon tube(pickup tube) and can cause it to surge due to the Nitrous sloshing around and with the tube bent, it's not low enough to pick it up. Also, with a 150 shot, you will probably lose about 75-100 psi each pass if you do not have a heater, ideal range is 900-1000, i have run more but be prepared cause it is a violent hit. Is your bottle in the cab sideways or is it in the bed or somewhere else?
Yeah man i say get you a gauge especially if you have a heater, that bottle builds pressure quick. I remeber one day was rollin around and had the heater on cause i was just havin fun and i looked back and it had 1450lbs of pressure. It didnt take it long at all and that wasnt on a full bottle either. I dunno what the bottles are rated to hold pressure wise but i have seen some gauges that go into the red at 1200 so i dont think its just a whole lot.
Jon
Jon
They have "Burst Valves", I was told that if i were to get a Nitrous kit. I need to have atleast a 3500-3600psi Burst Valve. This guy was in the navy, he told me bout air bottles that something messed up on and went through 2 bulk heads on a ship.
So i got a lil more research to do now...
Hope you figure out what your problem is..
slowlsx
Aug 10, 2015 05:33 PM
Gadgetized
Jul 7, 2015 04:40 PM
