Want to get 500hp out of 5.3
Old Feb 23, 2014 | 05:22 PM
JPaterson's Avatar
Default Want to get 500hp out of 5.3
I am a new member and was wondering a few things about my 2009 Chevy Silverado Z71 LTZ. It has the 5.3 with the 6 speed transmission. I want to get somewhere between 450-500 horsepower. What all can I do? And would a $5000 budget do it? Thanks a lot
Old Feb 23, 2014 | 05:30 PM
Chevy_King1500's Avatar
you will need some sort of FI.
$5000 will make a great start!
Old Feb 23, 2014 | 05:46 PM
JPaterson's Avatar
Would cylinder heads, FAST LSXRT 102mm intake, camshaft and long tube headers do it?
Old Feb 23, 2014 | 06:43 PM
You might hit 500 Flywheel with some killer AFR heads, 230+ duration cam and 102mm intake, but you would have a shitty driveable truck that would need a 4k + stall to even function lol.
Old Feb 23, 2014 | 11:34 PM
Vortec350ss's Avatar
Pretty much sums it up.
For your goals start picking what type of boost you like best...
Old Feb 23, 2014 | 11:58 PM
Three6GMC's Avatar
My buddies 2012 ext cab silverado 5.3/6 speed just did 519 at a local dyno day this past sat. He has a custom cam spec'ed by my tuner and since he had to do the vvt and dod delete he had the heads milled. Has pacesetter 1 long tubes and a 6.2 exhaust with a cutout. Also running a Nitrous Outlet 90mm plate with the 150 shot jets. Made 368 on motor 519 on bottle. Everything else is stock.
Old Feb 24, 2014 | 12:03 AM
2doorfury's Avatar
Cam and nitrous. You'll hit 500
Old Feb 24, 2014 | 12:25 AM
lsxperformance's Avatar
Dosent even have to be big cam and 500 is doable with spray. There are several ways to do it, 5k is a workable budget to get you into forced induction. Just don't forget about budgeting for fuel systems and tuning. Install as well if your not able/ comfortable with performing the upgrades yourself.
Good luck keep us posted!
Old Feb 24, 2014 | 12:42 AM
2doorfury's Avatar
Dont leave out a built trans. You can make all the power you want, but the first thing that'll go is that trans. And that'll be around $3kof that $5k budget. Plus you'll need a good converter, another $1000. If your mechanically inclined, get a cam kit and install yourself. Then find a used nitrous kit on here. I bet you could stay in the $5k budget or at least close.
Old Feb 24, 2014 | 12:53 AM
oakley6575's Avatar
Do you want 500rwhp all the time or do you mind turning on the bottle, making sure pressure is good, ect before making a hit. If you don't mind the extra nitrous work, then you can hit 500 easily and for a lot less money than going with a FI system.
