07 chevy duramax 2500 problem starting
Old Nov 9, 2012 | 10:57 AM
Tvoyles's Avatar
Registered User
Default 07 chevy duramax 2500 problem starting
A couple weeks ago. I drove my truck to Home Depot. Went inside, grabbed my stuff and came back out. Truck wouldn't start. I squirted a little bit of eather it fired right up. I've had no other problems till yesterday. I stopped at a stop sign and my truck died. I can't get it to start.. Anyone know how to help??
Old Nov 9, 2012 | 11:24 AM
Budakane's Avatar
Welcome tp PT!!!!! Im sure somone will chime in shortly on this
Old Nov 9, 2012 | 11:34 AM
03sierraslt's Avatar
When it was running how did it run under a load ? When is the last time you changed the fuel filter? Does it even try to fire or just cranks?
Old Nov 9, 2012 | 12:01 PM
nonnieselman's Avatar
fuel filter or water in the fuel is my guess...
be a cheap and easy thing to try.
Old Nov 10, 2012 | 08:56 AM
Tvoyles's Avatar
Registered User
It only cranks over.. I changed the filter in mid summer..I havnt pulled anything with it in a while.. But it has been running fine
Old Nov 10, 2012 | 09:01 AM
Tvoyles's Avatar
Registered User
I checked filter, put back on. Open bleeder and primed it.. I primed and cranked numerous times and have nothing
Old Nov 10, 2012 | 10:03 AM
gs7793's Avatar
I'm gonna go with cam position sensor. Sounds completely identical to the problem my dad was having with his power stroke
Old Nov 10, 2012 | 12:44 PM
Tvoyles's Avatar
Registered User
I have more info on this.. I've been letting my neighbor use the truck to go back and forth to work.. I found out that they have been running the full tank low, and then throw 10 to 15 dollars of fuel in when it gets pretty much dry.. A ? Is, if I change the fuel filter. Will it or does it reset that sensor
ferrellrooster
Mar 6, 2025 03:22 PM
shawn96gmc
May 17, 2016 04:15 PM
walledition
Jul 29, 2015 08:54 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
