MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
video of my 1/8 mile pass
Old 08-18-2014, 07:13 PM
Chevy_King1500's Avatar
Cool video of my 1/8 mile pass
https://www.youtube.com/watch?v=uT2Z...ature=youtu.be
22 secs in the video the engine seems it loses a little steam and then picks back up. i believe it was from the iat's creeping up past 140*F
This was the slower pass of the day but better mph @89.8
also this was the pass my carrier bearing let loose
Old 08-18-2014, 07:21 PM
oakley6575's Avatar
How much boost can you build on the line?
Old 08-18-2014, 07:29 PM
Vortec350ss's Avatar
Sounds pretty good.
Generally when high IAT's pull timing it doesnt let it back in... it sounds like a quick bog then it comes back.
Old 08-18-2014, 07:37 PM
im thinking 5psi, you can see where i push past 3000rpm and then the 2step brings it back down.
so a little tweakin on the 2 step and turn the boost up i think i could leave on more rpm and boost
Sounds pretty good.
true, timing was down to 15 on this run. should have been 19
but i did get it to shift around 5600 on the 1-2. having the same problems with the 80e not wanting to shift right
Old 09-02-2014, 07:26 PM
hsiriyob's Avatar
whats your 60ft look like(if you dont mind sharing)? Any suspension?
Old 09-02-2014, 07:37 PM
1.74 was best of the two before the truck broke
this one was 1.82
28x10-16 hoosiers
tru trac stock 3.42 gears
suspension is 3/4 drop
shackles and hanger in the back. 6* pinion shim and my carrier bearing relocated.
i need some type of traction bar to keep my axle from wrapping... you can feel it moving around a lot
Old 09-03-2014, 06:43 AM
11 sec. Truck Mod
TIM Z's Avatar
Truck sounds sexy man !!!
Old 09-09-2014, 11:43 AM
darnie's Avatar
Looking go man should met low low 12's? Hoping to be there one day
Oobray
06-13-2022 03:38 AM
pittman
01-19-2016 07:06 AM
Choda
07-21-2015 03:47 PM
fcompean
07-15-2015 09:55 PM
Breitling
07-06-2015 04:50 PM
Quick Reply: video of my 1/8 mile pass
