MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
Trying to launch on drag radials
Old Apr 27, 2007 | 10:57 PM
  #21
BADMOFO's Avatar
Cuz I AM a BADMOFO
Can't tell from the video, but it would also help if you tried to launch it on concrete. I'd say 20psi, longer burnout...until they "chirp" at the end of the burn out as you're letting off, and then back up into the burnout patch on concrete and try it. The track starting line is waaaay stickier. You got a bunch of gear @ 4.56 to only be running a 28" tire. I think a 295/65-15 ET Street Radial would be your best bet. Part#3762R. They don't make a decent tire size in 17's, but you shouldn't have a problem finding a 15" wheel to fit your truck, except that you gotta buy some
Other than that, the truck LOOKS and SOUNDS fuggin' killer!!!
Old Apr 29, 2007 | 12:23 PM
  #22
litreddevil's Avatar
Banned
you will have to do a better burn out than that to heat them up and put about 18psi in them a i bet they hook
Old Apr 30, 2007 | 02:21 AM
  #23
NORCAL TBSS's Avatar
Restricted User
i have the same tires.
22 psi and do a burn out until they hook dont stand in same spot. power break it just to spin then let go of the break and mash on it until they hook up. and they should be fine.
walledition
Feb 24, 2026 03:27 PM
kainzien
Nov 10, 2023 11:37 AM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
moregrip
Jul 26, 2016 11:21 AM
Slammed silverado
Sep 28, 2015 06:14 PM
