Tan 327 and Onebadrubi @ Centerville 10-14-06
Hey tan, I think we/you should really try just brake stalling that thing till it starts to spin, off the line. Yah its gonna spin but you can fix spinning easier then hooking and cuttin 1.9, IMO.
I had tons of fun. And yes we needed waffle house footage of UNO!!! "how bout them grits boy?"
Cody I texted you bout caleb, guess you already went to bed. If It cant be done teusday I coudl leave work about 2 friday probably. but that is as soon as I could do anything.
Oh and to gloat a little bit, i cut a 1.9 60' on street tires on that last run, the blue truck. CANT WAIT TILL MY OTHER SLICK GETS HERE!!!
I'll get ahold of you later so you can tell Caleb something, it might be next week before I can do anything though.
Originally Posted by TurboGibbs
Sweet video and killer runs.
10.55?
10.55?
Originally Posted by Tan327
Yeah that was onebadrubi's pass on the 125 shot, sucks that he was on street tires. Lol, you know this is just a 1000' track though right?
I'd say the only reason it pulled a 1.92 is because of these 3.73's, when the 4.10's go in it should pull some 1.7x's pretty easily.
great runs by the way and very consistent
Originally Posted by bluecajun5.3
how was the weather? with your mods even with the 3.73's you should be pulling some mid 1.8's. do you have the tm removed? sounds like it hesitates when it shifts.
It's running on a very base tune, the only thing we've changed since the cam swap was the timing and idle tables. And i'm pretty sure the A/F is off big time.
Here is what I don't understand, when I got to the track I pulled an 11.06 in high 70 degree weather. After that I let it cool down some and pulled the tailgate and passenger seat out. So the next pass the truck was at least 110-120 lbs lighter, and it was mid 50 degrees out.
I though surely it would at least drop a tenth, but the best pass was an 11.00 compared to the full weight & in the heat 11.06. I did bump the timing up between those runs to 31 degress so that could've been a problem. Maybe I was expecting too much, but it just doesn't add up..
