MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
7.62@92 6.2L Z71 Vid
Old Feb 3, 2010 | 02:49 AM
  #31
BadManLS1's Avatar
12 Second Club
Originally Posted by stock48
His truck runs better than you think. There is a HUGE difference between a 4x4 running in 4wd vs a 2wd. It's not just the extra weight its the parastatic loss of the Tcase, extra diff, cv joints, u joints etc combined with the front and rear end being binded together. The truck is almost in a bind on dry pavement when 4wd is engaged. AWD is alot more forgiving due to the viscus coupling that eases the tention between front, and rear diff.
My truck picked up 3mph in just the 1/8 mi just by running in 2wd. Also was with an unspooled launch.
Thanks! I'm gonna try some 28in drag radials in 2wd next time and see if that picks up any.
Old Feb 3, 2010 | 03:42 AM
  #32
Most Hated's Avatar
wat if u put it in auto 4wd , nices times btw get some 410's in there
Old Feb 3, 2010 | 08:10 AM
  #33
BadManLS1's Avatar
12 Second Club
I think auto 4x4 will break something because the back wheels will spin first then the front snaps in.Gears might help but I'm not changing both front and rears since we need to use 4x4 for off-roading.That is a lot of cash for the minimal gain.
Old Feb 3, 2010 | 04:40 PM
  #34
exodus's Avatar
Hell yeah the truck runs good! You leaving in 4WD or 2 wheel?
Old Feb 3, 2010 | 04:41 PM
  #35
exodus's Avatar
sorry....didn't read....im a dumbass. lol
Old Feb 3, 2010 | 04:42 PM
  #36
Luke03's Avatar
Congrats on the new best! I say that is a great time for having a small stall, small cam, and being 4WD.
Old Feb 3, 2010 | 04:49 PM
  #37
Luke03's Avatar
If you don't mind me asking where are your shift points set at?
Old Feb 3, 2010 | 05:05 PM
  #38
BadManLS1's Avatar
12 Second Club
I have it set at 6200 in each gear.
Old Feb 3, 2010 | 05:07 PM
  #39
dlt76028's Avatar
Originally Posted by BadManLS1
I got rid of the VVT cam and cam gear, put an ls2 timing cover with a gen 3 224 cam and ls7 cam gear. I'm using the Lingenfelter Reluctor box 58 to 24 tooth. Also using a map, cam, and knock sensor extension harness from Lingenfelter. You also have to get the injector conversion adapters from gen 3 to gen 4 style injectors and you have to use the Torque Rush X-link for the TB to open 100%.
wow thats alot more then I thought for the swap.
Old Feb 3, 2010 | 05:30 PM
  #40
Luke03's Avatar
Ever thought of raising it up? I would think that thing would pull all the way to 6800-7000.
