Ls1 swap in 92 s10
Yep !
Try s10 forum , you will find lots of LS swaps there into dimes.
Sounds like a cool project, i bet a 5.3 / 5 speed in an s10 would not only be fun to drive, but should pull down some good MPGs too.
Linkage for auto shift. I can mount b.m. Shifter on floor for auto 4l60e
Nobody has been able to get the column shifter to work with a LS automatic swap. You can swap with a 5 spd if you get the 5 spd from behind a LS motor. The shifter hole will even line up between the trucks.
Current performance sells conversion motor mounts, headers and wiring harness for the swap.
If you get the a/c lines from a 4.3L s-10 and a conversion brackets Dirty Dingo Motorsports
You can even keep your a/c, yes it will clear the hood
PS - aluminum LS motors weigh about the same as the original 2.8L V6.
