Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
Ls1 swap in 92 s10
Old 02-23-2012, 09:14 PM
Go5.3tt06's Avatar
Default Ls1 swap in 92 s10
Is there any info I could find and see how it work swap 5.3 and 5 speed manual into 92 s10?
Old 02-24-2012, 04:56 AM
11 sec. Truck Mod
TIM Z's Avatar
Yep !
Try s10 forum , you will find lots of LS swaps there into dimes.
Sounds like a cool project, i bet a 5.3 / 5 speed in an s10 would not only be fun to drive, but should pull down some good MPGs too.
Old 02-24-2012, 07:19 AM
Go5.3tt06's Avatar
Shoud I just go for auto?
Old 02-24-2012, 12:51 PM
reiners88's Avatar
If you can find a complete setup out of a truck with wiring harness it would be the best way. An auto would be simpler if you are already auto on the s10
Old 02-24-2012, 01:03 PM
CC05's Avatar
Current Performance. 727-844-7570. They're really good about LS swaps in the S-10 and Colorado. They're also located in Port Richey, FL.
Old 02-28-2012, 08:05 PM
Go5.3tt06's Avatar
It's 5 speed with v8 but I can do auto for 5.3. I wonder how I can hook up
Linkage for auto shift. I can mount b.m. Shifter on floor for auto 4l60e
Old 02-29-2012, 07:21 PM
reiners88's Avatar
You could do that. It's more preference than anything.
Old 02-29-2012, 10:14 PM
cttandy's Avatar
Nobody has been able to get the column shifter to work with a LS automatic swap. You can swap with a 5 spd if you get the 5 spd from behind a LS motor. The shifter hole will even line up between the trucks.
Current performance sells conversion motor mounts, headers and wiring harness for the swap.
If you get the a/c lines from a 4.3L s-10 and a conversion brackets Dirty Dingo Motorsports
You can even keep your a/c, yes it will clear the hood
PS - aluminum LS motors weigh about the same as the original 2.8L V6.
Bluecollar Hotrods
03-13-2017 05:02 PM
Denali08
08-09-2015 04:34 PM
Jake99
08-08-2015 07:56 AM
Go5.3tt06
07-20-2015 08:00 PM
Black-Syde
07-06-2015 02:12 PM
Quick Reply: Ls1 swap in 92 s10
