Question for you "L" guys
Any guesses on what a newer Lightning with cat back, intake, TB, and a tune would run? And how about one that has also been pullied? I'm trying to gauge if I can keep up with you guys while staying N/A... I doubt I can take one without some heads or LTs and E-fans, but I'd like to see if I can run side by side with my current set-up.
Originally Posted by 2004svtlightning
what are you sayin?
what are you sayin?
I think he's just jealous though
The exhaust on a 99-04 L's flow really well, without long tubes, cat-backs are for sound, most see no gains except in the "seat of your pants" dyno
Without the help of a pulley the other mods really don't do much for power. With cat-back and CAI I saw 343 hp and 413 trq
Originally Posted by 203Cree
With what you just listed, low 13's probably.
With pullies, it depends on the size and the tune. Anywhere from high 12's to low 12's, sometimes 11's if they're setup right.
a power adder is a power adder mechanical or chemical so you have to spray to keep up with a supercharged truck. Just watch out for bottle fed lightnings a 50 shot once it is compressed through the blower will add closer to 100hp
? would a NOSzles system for a mustang 4.6 work on our trucks so you could control the amount of nitrous better. i think a nitrous kit on my truck would be cool
the more boost = more air and nitrous if used packed into the cylender if the nitrous is added on top of the blower it will compress the same as the air if it is added below the blower it is easer to controle the shot. it will still have an aditional + of coolling the air charge if you add a dry shot start small and push your injectors full rich then back down you may wish to have a flip chip so you do not run excessively rich when not using your nitrous and remember lean is mean but rich is safe
