Zo6 Cam?
what size pushrods are people with the z06 cam running i have done searches and seen many people say a variety of sizes but would like to know what people are using is 7.4000 enough like Whitelightning says?
A cam with a smaller base circle then the cam used in the 5.3, is not gonna give you the advertised lift values of the ZO6 cam. I'm not saying it will be noticeable outside dyno testing, I'm just communicating what I found out while researching the best cam for my application. The longer sodium filled valves in a ZO6 make up the difference, to get the same lift value (.550) with a shorter valve you gonna need a longer pushrod.
