Zo6 Cam?
Old Aug 20, 2008 | 11:47 AM
white lightning SS's Avatar
You can use Comp or Trickflow 5/16 x 7.400 inch moly push rods. Stock pushrods have been known to bend at higher RPm with higher spring pressure such as the yellow Z06 springs.
Old Aug 20, 2008 | 01:13 PM
OLD BULL's Avatar
My engine only has about 40,000 miles do I need to change the timing cover gasket and crank seal?
Old Aug 20, 2008 | 03:42 PM
MPFD's Avatar
11 Second Truck Club
ZO6 cam has a smaller base circle then standard ls cams have. You won't get all the lift that cam is capable of if you reuse stock length pushrods.
Old Aug 20, 2008 | 03:48 PM
sk8rshorty's Avatar
what size pushrods are people with the z06 cam running i have done searches and seen many people say a variety of sizes but would like to know what people are using is 7.4000 enough like Whitelightning says?
Old Aug 20, 2008 | 06:28 PM
acethedragon's Avatar
on the z06 heads they used longer valves to make up the difference. same pushrods. use the 7.4" to be safe
Old Aug 20, 2008 | 07:02 PM
AdioSS's Avatar
12 Second Club
OK, just to humor us, explain why not
Old Aug 20, 2008 | 11:19 PM
charcold-bowtie's Avatar
when i went through this debate, based off of old info i found posted by parish, among other, you just lose some preload. I did the swap, with 7.400 pushrods, no complaints here.
Old Aug 21, 2008 | 08:05 AM
zippy's Avatar
That is correct. I haven't installed my longer pushrods yet, but I plan to re-dyno after I do. The LS6 valves are .6mm longer.
Old Aug 21, 2008 | 09:00 AM
hellbents10's Avatar
LS1Tech Sponsor
I use 7.400" with the ls6 cams.
Old Aug 21, 2008 | 10:21 AM
MPFD's Avatar
A cam with a smaller base circle then the cam used in the 5.3, is not gonna give you the advertised lift values of the ZO6 cam. I'm not saying it will be noticeable outside dyno testing, I'm just communicating what I found out while researching the best cam for my application. The longer sodium filled valves in a ZO6 make up the difference, to get the same lift value (.550) with a shorter valve you gonna need a longer pushrod.
