wondering what this setup would do
Old Oct 17, 2013 | 09:18 PM
Noah Burns's Avatar
in the 6L the 224R would be sweet, I'd probably go with the 228R out of just that list if it were me but I tend to go big when it comes to cam choice.
Old Oct 17, 2013 | 09:27 PM
bluebommer07's Avatar
cam across these also
239/244 | .62x”/.59x” | LSA112+3
242/244 | .61x”/.61x” | LSA112
Old Oct 17, 2013 | 09:28 PM
Originally Posted by GMCtrk
To put it in perspective:
Stock LQ9
1 7/8" headers no cats
4.10s
Yank PY3600
On very heavy Toyo 285/60/18s. 2.03 60'
That setup yielded a 13.73 1/4 mile. On some track wheels and tires and a better 60', it's probably a low to mid 13 sec run.
With a 212 cam, a crew/ec would be a high 12 second truck.
thats carzy for a heavy cc check out the other cams i posted gmctrk
Old Oct 17, 2013 | 09:43 PM
craigsix's Avatar
i would go with 4.10s ls motors like them.
Old Oct 18, 2013 | 10:29 AM
GMCtrk's Avatar
I'm almost certain you would be less happy with the big cams. There's a big difference coming out of the hole with a 60e versus the 80e. You need power down low to turn it over when n/a.
HotRod mag did a 6.0 test years ago, 210/218, 220ish cam, and a 230ish cam. The 210/218 had the most average power across the board easily. Only until 5k up did the bigger cams surpass the baby cam. Bottom line, comes down to where you want your power. But even them you still need the right converter with the bigger cam to put it in its powerband. I'm running the mid 220s eps cam. It's a good overall cam, give up a little down low and gain some up top. I'll probably switch it out for a smaller cam soon since I've got the turbo to take care of the top end.
Old Oct 18, 2013 | 12:05 PM
Blackpanther99's Avatar
3200 stall, 4.10gears and TSP 224r or 228r on a 112lsa would be ideal.
Old Oct 18, 2013 | 01:55 PM
A friend of mine had a old setup that contain
Stock lq4
Tr224
Intake I believe was tbss with 90mm
Prc heads
3400 converter
Made 409 but that was through a 60e
Considering I'm running 80e ill be mid 380s I'm guessing ?
Old Oct 21, 2013 | 07:42 PM
Duntov1967's Avatar
n/a lq4
212/218 .561 .590 112+2
2800 stall
80e
3.73 gears
p&p 243s
pacesetter lts
3in ypipe
nnbs intake
90mm tb
cc truck
275/60/17
265/35/22 tires
just was wondering how it would do on the street?
Good combination. Stick with the 212/218 and you won't be disappointed. But 4.10 gears would be a lot more fun.
Old Oct 26, 2013 | 05:11 PM
think i will ill keep everyone posted on the process of the build when i start
Old Oct 26, 2013 | 05:55 PM
