will the LS6 cam fit??
Old Dec 15, 2007 | 06:40 PM
fastgmc53's Avatar
14 Second Truck Club
Default will the LS6 cam fit??
I see that the LS6 stock cam is the biggest will it bolt in the LM7 and what else is needed IE.. springs and or pushrods I can get the stock parts cheaper than aftermarket stuff so I'd like to stick with stock.
Old Dec 15, 2007 | 06:50 PM
00Silv4.8's Avatar
u should do rods and springs with it. A converter I dont think is necessary for that cam but a small one might make it feel better
Old Dec 15, 2007 | 06:57 PM
fastgmc53's Avatar
one more question....If I drop in a 6.o with my intake assembly do I need the 6.0 ecu? I have the superchips programmer in mine now
Old Dec 15, 2007 | 11:07 PM
adam1803's Avatar
For the cam you would need springs at a minimum. Pushrods would be nice but not .completely necessary. If you drop in a 6.0 you will need a tune for a 6.0, either buy getting the ECU or have someone flash one into your ECU.
5.3Okasai
Mar 9, 2022 01:07 PM
ARC
57
Feb 21, 2022 10:54 AM
The_W
Oct 28, 2015 09:00 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
Aboss
Jul 9, 2015 10:28 AM
