why not a ls6?
Originally Posted by dry_kill
first off, im hung like a ******* moose, secondly i think ima go for it since its a good deal and i can pick it up, and thirdly, since it puts out around the same power as a 6.0 i dont see why i shouldnt do it, fourthly, please leave the "dick" out of my thread, im a man that loves women so you know, try to talk about some poonie instead of dick
first off a shortblock doesnt make the same power. listen carefully so youre not misinformed. a LS6 short block and LS1 shortblock are the same internals. minus the cam. now some 01 and 02 Fbodys came with LS6 blocks. so i can sell you a LS6 shortblock tomorrow. Beastmode recently picked up a motor that uses a LS6 block. they use the same crank and everything. now if it was a complete long block then yes it would make power actually 405HP but since its a shortblock. that only means the block and rotating assembly. which isnt nothing more then your typical flat top piston ls1
Originally Posted by Quik
hahahaahaha funny *** **** there
which is fine, so what exactly makes up for the extra hp in a ls6? heads, cam and intake?
so if you have a small dick then saying "I have a LS6 block in my truck" then go for it
Hes just ****** with ya Charles!
The extra cubes will help make more power across the rev range even with your stock heads. Ideally you'd like to have a set of LS6 heads and the intake to maximize the upgrade. If your truck has an iron block you'll see a weight savings too.
Good luck,
Richard
Good luck,
Richard
